Does anyone know where I can get a replacement power transformer for an HK TA5000-X? It appears the high voltage winding is bad due to a short - it took out 2 large resistors (3.3 OHM 5W equivalent). It only has 155 volts on the 370 volt winding.
The XFMR number is FT4725648.
