I recently came upon a harman kardon 3470, looks ok physically but selling as broken. So I was looking for service manual (found) and adjustments that could be completed.
I was not able to find an idle/bias adjustment for the final power amp devices? And no DC offset adjustment either.
Just curious if others have worked on these units?
Thx.
--Joe
Thx.
--Joe
It's runs in Class B so a few miliamps of current will stop any crossover distortion.
There is no DC offset because it doesn't need any. The front end transistors are matched.
So I would equate this to AB operation 🙂
Nonetheless if everything is matched and within design tolerance no adjustment would be required. I get it.
Thanks for the reply.
--Joe
--Joe
Typically for an EF output stage the optimum bias current is in the 50mA to 100mA range, ie quite high - you might want to err on the lower side for cooler quiescent conditions in the amp.
That's what I was figuring. But there is no variable resistance in the driver stage to adjust. This is a fixed bias amp. In a perfect world I'm ok with this but components drift and not always in the same direction.
I checked a similar HK (3480) that uses a pot in the preceding stage so I could hack this 3470, not sure yet.
Thanks for your reply.
Yes, already have that.
Concluded this is a fixed bias design.
- Harman Kardon 3470: idle/bias setting
