I just found in the garbage (incredible what people are putting to garbage) a nice Harman-Kardon 330B. I just put the 2 speaker fuses in, then the amp works just fine. The tuner seems ok too. It has a discrete phono stage, separate bass/treble adjustement for left and right, AM-FM, aux input (for CD) and even a preamp output. It is all discrete amp and tuner.
I would like to have the service manual or just the schematic in case it breaks down.
I'll give it to one of my boys for Christmas.
Thanks in advance.
Thanks in advance.
Yes, it is amazing what people throw out! I found an HK 330A in the garbage, but mine has blown output tranistors I think. Cosmetically it is pretty good. I also found a Pioneer SX440, which I haven't fired up yet, but looks mint. I'm in Toronto, noticed you're also in Canada. Is this a Canadian thing to junk good old stuff?
If you get a copy of the 330B schematic, could I get a copy from you? It might be similar enough to mine to help me fix it.
Ron
Ron
Schematic
Yes I'm in Montreal, I'll keep this in mind.
I found the user manual and specs on www.harmankardon.com
Bye...
Bye...
Found It
Hi Transducer. An other user on this forum, that provided me with HK manuals in the past, was able to provide me this one again.
Transducer, just give me your email and I will send you the url to get the manual.
Thanks everyone and long life to diyaudio.com
By the way I tested my HK330B and it is working perfectly, I got (before clipping) 22W in 8ohms, 33W in 4ohms.
Bye...
Bye...
I've got a 330b also,Blown output transistors...Somebody tried to replace one with a TIP3055/2N3055 in a T0-220 package...
I guess the original 2SC1107 outputs are impossible to find now.Does anyone know of a suitable sub?
Perhaps we can throw a 330b ressurection party,and get all these 330b's singin again. 🙂
I believe someone here sent me the schematic aswell..
PMik
noticed you found a h/k service manual,
is there one for a avr 507 or avr 330?
cant get into the hardon kardon database to look 🙁
thankyou PMik much appretiated mate 🙂
strange as the harman kardon avr 507 theres no service manual anyware? wonder if its because its a 'Limited Edition' 50 Year Jubilee Range??
Np 😉
geezer
we better not talk
about this Google wonder
or we might loose
this supply of HK schematics
Cheers
geezer
we better not talk
or we might loose
Cheers
is there anyone on here know who can brouse the database or anyone service technitions on here who can tell me if the avr-507 is shared with a diffrent model? looked through avr 230,avr 235,avr 330, ( all i know the avr-507 is its a europeon limited edition model)
i thought the avr 230 was promicing as its the same board locations etc, that was untill i check a cap and it was a diffrent value 🙁
i emailed h/k apparently they said tryed to send it me me 4 times however my emails bouncing and wont acept 8mb attachments,
well that dont wash, as i have had large attachments sent before off friends, think they are trying to pull the wool over my eyes,
i would even be prepaired tp pay for one if i have to.
so i know there must be a manual for this model or a diffrent model that shares the same manual with the avr 507?
- Harman-Kardon 330B schematic needed
