Hey all,
I have a Hafler P3000 amp that has the full neg rail on outputs (-67V).
Looking at the schematic, I can't see a real way to get -67v on the red speaker out referenced to black, unless that C5 (6800uf, 80V) cap is bad.
Other channel working fine.
The gain / volume pot on this channel was damaged (bent / disconnected from PCB), and has been replaced. did not seem to have any effect on the neg rail DC on outputs. Also has the Thermal LED lit... any ideas?
I know these transnova cap coupled output amps a a bit goofy, like the Acoustat TNT amps...
Is one or more of the output fets shorted/ failed in the suspect channel?
is it worth pulling them out individually and testing them.
This is how I found dead mosfets in my ALEPH 5 some time ago...
George
George
Yes, but to get neg rail on the Positive speaker out per the schematic - seems to me only way is to go through the bad cap. If one of the outputs (pin 1 to 3) were shorted,the Fuse would blow,correct?
Don't mean to disagree, but these Transnova's are a goofy design...
is that 67V with a load attached? without a load it is possible that the caps float up to the rail if there is a shorted output. with a load that should stay at "0" volts. unless the cap is shorted like you said.
Didn't think of that...I have a 8 ohm dummy load I can throw on the amp outputs. I also will check the working channel for 67v unloaded....I don't think the output fets are bad, and they aren't cheap...
It wouldn't even have to be an 8 ohm load... a few kOhms or so would also do. Excessive leakage (up to eventually shorting out) isn't unusual in electrolytics showing their age.
- Hafler P3000 -67V on output
