GW1858 vs random Wharfdale 18" in WAW OB
I pulled the trigger to the tune of $200 for a pair of Goldwoods, as I thought I could do a little bit better than the Wharfdale 18" drivers I spent $100 on. The Wharfys have a measured fs @40 Hz, otherwise I cannot find any specs on them - other than that they're 4 Ohm speakers.
Checking the Goldwoods, they do fs at ~ 30, just as the spec says. They are 8 Ohms. A reknowned driver for WAW OB use. Replacing the Wharfs and tuning things up, I'm not hearing any difference at all in the bass performance of the system.
They could be returned, but that just seems too "American/Walmart/Amazon" a thing to do, to me. The seller did and the speakers are doing everything they're supposed to do - it's just that $200 worth of difference isnt showing up in my own perceptions. The Wharfdales are actually the better constructed speaker of the two Chinese manufactured units, having a cast frame - vs stamped.
I suppose I'm not the first DIYer to drop some cash on a piece - and hear nothing at all from the additional expense.
The OBs have no H frame for the woofers. Should I make a push to get at least the back tunnels constructed to bring these to a bit better life? I'm using a reverse rising response to 35 Hz starting at about 110, where the top has already started to rolloff. The attached pic shows what the OB looks like.
Thanks!
Thanks AmpsRus. I'll start looking into sourcing lumber for the H frame tunnels.
Still, I have to wonder if I put those around the Wharfdales... I guess I'm wondering if the extra drop to 30Hz fs bought me anything - or I was never hearing sound below 40 anyway...
