Guitar Amp Hum Question
Hi Guys,
Ok I am back at it on another project, But I have a couple questions about what to expect.
Primarily, I am building a Deluxe 5E3
I have everything punched mounted and partially wired up. Heres my question. I have the entire Output & Power sections completely done. up to the volume Control. I plan on using a slightly different Pre-amp section so I connected Pin 2 of the 12AX7 to the wiper(center) on what will be the master volume pot.
1 (left)outer pin of pot to ground, Other (right)outer Pin of pot will be my input.
I Decided to power up the unit at this point to confirm functionality of the work to this point.
So as it sits, I have a 12AX7 Driving a pair of 6V6's into a 8 ohm cab.
Should I expect hum without a sources connected?
The Amp does respond as expected when the input pin of the volume pot is touched.
BUT, I thought If the pot was rotated it should kill the open input hum?
Gene
You're right, with the grid grounded, there should be no hum. Hum could be caused by supply ripple, a bad grounding scheme, or even induced directly into the output transformer.
Assuming no wiring mistakes:
Quick check list:
Is there hum without the 12AX7?
If yes, check for ripple, and check transformer orientation.
If no, does the hum change with the pot setting?
If worse at low volume setting, check grounding.
Are the heaters floating? They should reference to ground some way.
Whew, Got it.
Da olde guy had a brain glitch, I had a sheilded lead from pin 2 (grid) to the pot, The outer shield to outside connection on pot, Inner to wiper. BUT, forgot the ground!!! and therefore the shield only contributed to the problem. Attached ground, Problem solved!
Sometimes I wonder why I just didnt stick to RC Aerobatics, At least I was a national champion at that as well as a top designer. But NOOoo I got bored and switched to this stuff:whazzat:
Eh, either way, I am having loads of fun learning. Your response got me looking at the grounds and bingo!
gene
BTW Grid shorted = Dead silent
RC Aerobatics, bet thats expensive when things don't work right. My buddy flew the RC pylon races. Grown men cry when things go wrong there. He gave that up too, lots of broken parts
Honestly, In my particular position it wasn't bad. I had a sponsor on the radio equipment during my last 5 years. I flew my own design 5 of those years, And since I owned the kit manufacturing co, It was fairly easy to keep actually costs at a minimum. And of course all trips to competitions were advertising expenses.
In 11 years of competition, I lost 2 Models, Both valued just over $2500.00 each if you had to buy them. But actual cost was about 1/10th.
Really besides regional contests lacking any serious competition, The primary reason I got out was basically age (old eyes). Though I could literally close my eyes and know the orientation of the model it had become an issue due to long term exposure to the sun starring at the sky 2-6 hrs a day " Nearly EVERY Day". Even Now, 5 years later, there is no such thing as a bright enough work area. Had I not used the best protection of the times, No doubt I would be legally blind. I just had my first restriction put on my DL this past May, At age 51??
gene
Have you gentlemen tried wearing an Optivisor when working on projects?
I began wearing one (gift from my dad) when building fishing rods.
Now, whenever I can I put them on for working on circuitry and building guitars, etc.
They are fantastic for doing the fine finishing work on the guitars!
John
John
I really need a pair. I have reading glasses for near field viewing but for doing electronics in cramped spaces, with a single thread of stranded wire going its own way...
I keep saying no more ship in the bottle builds, but then I have a project and no larger chassis made up, guess what goes in the little one? My RC experience had been, build - crash - fix - fly - fix - fly - fix... Got into car building after that. All the fixing done me well with the acoustic guitar I am building now though.
