Guard rings for op amps
properly driven guard rings actually bootstrap away PCB dielectric errors as well as DC leakage
but the added capacitive coupling can give destabilizing positive feedback too
so you can in principle get some of the advantage of exotic PCB materials like Teflon with careful layout and driven guards
but its not often that such concerns are in your top 10 unless you design condenser mic or guitar pickup preamps
Guard rings are used in instrumentation applications where the transducer/source being amplified is at an extremely high impedance. Can't think of an audio source that matches that discription so I very much doubt they could be necessary.
Using high standoff IC sockets would increase the supply impedance at the opamp pins, this cannot improve the sound. Go for the lowest impedance power supply you can manage.
