Grounds concept/direction/advice
I have built a number of perfboard circuits, mostly chip amps. I usually built each module as a monoblock, ala chip amp kits; each with its own star ground. They work perfect individually, however in stereo or bridged mode, the sound one channel dominates the other channel.
I believe the problem is the location of common ground because i don't have issues with circuits i build as stereo.
So, in an aid to designing better perfboard grounds, (where ground planes are not possible) Should I:
1) Create 2 star grounds, one for signal and one for power
2) Pull out the common grounds from each channel into a common ground at psu ground
3) Connect both grounds at every possible opportune, ie signal, power and speaker ends.
Any advice/debate would be lovely
Chuck
Puffin said:
Are you referring to a Bridged or parallel circuit ? Which chips are you using ?
Bridged.
My Parallels oscillated too much, i was too lazy to match the chips thinking it was suffice that they were from the same batch.
Chips.. LT1210 (w/servo), LM1785(inverting), LM3785(non-inverting)
