Grounding on M441 and M402?
Hi folks, new poster here.
I'm in the process of racking up a set of these, and have a question about grounding. how do you think I should wire the input/output grounds? should I tie them both off to the ground pin, lift the output ground, or tie one or the other to mains earth pin?
I am using a the following power supply, which differentiates between the mains earth pin and ground pin relative to the 48vdc pin.
http://www.clrwtr.com/PDF/Sola-Hevi-Duty/Sola-81-83-OEM-Power-Supply.pdf
What the pcb lists as "V-" is actually the ground relative to the 48vdc output.
Thanks for any help!
