Ground Zero GZNA 1.2500d Type 2
Received this amp... Output Stage damaged.. No Fets inside. Drive Board one mpsa 56 was burned and the 220ohm resistor..
Problem is now,That If Input the Driver Card in place,without mosfets, the 220 ohm directly Starts burning...cant find the Problem.
I replaced all Transistors in the middle row. even if they measured ok... All other transistors on the board i have removed too, and checked them. All ok.
Without driveboard, i have a current draw from 1.67Amps, with board inside 2.6Amps... Checked all solder points for the output fets, and also the diodes ...
Q123 been defect in the beginning. MPSA 56
