Transformer with only 2 x 24V secondarys not good for stereo? I am confused, having a groundloop...as soon as the 2nd chinch is connected there is a humming. I thought i can get away with it... any idea?
Yes.
OK, the thing is, both channels connected to the powersupply run perfectly quiet, aslong as one of them are disconnected from the powersupply. As soon as i connect the frontend-ground from the other channel to the powersupply ground it humms.
Got a picture of the setup? Are you using star ground and separating chassis ground and audio ground with a ground lift?
Glad the 4x24v transformer seems to have solved your problem.
- Ground loop
