Ground Loop Isolation - for cable TV ?
Yes, I had audio hum resulting from the coax cable's ground, and resolved it with an Iso-Max VRD-1FF -- inline to the cable box.
Hum is 95% gone.....that's acceptable for me.
HOW DO I MAKE something similar ?
Is it just inline caps ?
Why can't I find any DIY ideas for this ?.....(besides the common back-to-back 75/300 ohm antenna transformers.)
=FB=
I still don't understand why there isn't an easy diy solution ?
If they're caps, what values ?
Those Jensen isolators have a stated frequency that they filter/isolate, which I guess is crucial, so as not to degrade the video signal.
I believe they use caps too.
Many of us use ground isolation in our audio projects including me.
(10ohm resistor, and 100nf cap between earth and circuit)
=FB=
