Hi everybody, i'm a musician with a lot of stuff that doesn't work. I've been having problems with my PA and recently inherited some old tube amps that could use some work. I play a lot of garage/surf/punk, but i like all kinds of music, I also play in a band that breaks a lot of stuff. I've never really worked on musical equipment much, but I've got the physical part down; I've built wiring harnesses for cars from scratch, I've fixed computers, and I even took a robotics course once. I could however really use some help with the more audio specific components, and the theories behind them, and this site seems like a great place to get started. I feel like Im going to learn a lot and Im sure ill be bugging you with noob questions soon.
~Austin.
~Austin.
Hi Austin, with that background I'm sure you will do fine! Plenty to read here and plenty of help at hand. Do a bit of research as to what you think may be an issue and then start asking questions and you shouldn't go wrong 🙂
Tony.
Tony.
- Member Areas
- Introductions
- greetings from California
