I found this page of a gentleman making a computer case over the course of a year. His work is absolutely amazing. I have learned a tremendous amount from just looking at the pictures. The finished piece is on page 36.
Cygnus X1. - Overclockers Australia Forums
My big question is how do you keep a file clean after working on aluminum?
There's a brush that's designed for that, or just use a piece of brass to push out the big bits.
jeff
You can use your file on a piece of chalk before using the file. This makes it very easy to remove the small particles sticking in the grooves of the file. As mentioned elsewhere you can use a special brush for this and then it becomes even easier.
Karsten
A file brush is only so good. I can spend hours with a nail picking out the aluminum. I'm going to try the chalk. - Thanks Karsten!
Anyway, you should really check out this guy's computer case. It's some of the most
impressive work I have ever seen, done it a hacksaw, homemade brake, drill press and scroll saw. I learned a boatload about home chassis fabrication.
Cygnus X1. - Page 36 - Overclockers Australia Forums
I'm surprised he doesn't use a nibbler also. How does he glue the paper to the aluminum sheet? It's really strange to see EXACTLY the same plastic clamps that I have in photos from Australia.
I think he lays masking tape onto the aluminum and draws his pattern on it. I have seen people spray adhesive onto the back of laser prints and lay them onto the metal. I agree about the clamps. Seems to be an Aussie standard.
I've been taping graph paper to the metal. It does look like he's using some kind of tape, but most of the tapes I know of are not that good for marking. The surface of the tape is too rough and doesn't take ink very well. Maybe there's a special tape they use? I think the pros use bluing and put scratches on the metal to outline cuts and bends.
Yeah, I was at the Home Depot today and didn't find any kind of tape that would work well as something to write on.
I bought a spring powered punch and a scribe, as well as other stuff. I don't see what's wrong with just writing right on the metal, unless you make mistakes I guess...
That wood work is insane. He could have done it half the time if he had a vacuum bag and veneer. Jeez!
Wow, I finally went through all of his photos up to page 36. Incredible. It's completely hand made.
You can get repositionable adhesives and use any paper. 3M, others sell it. This is the kind of stuff an airbrush artist would use. The adhesive is not weak, it just is not permanent and doesn't leave any residue or is easily cleaned with a wipe. Some people use rubber cement but there is a trick to even application for very precise positioning and marking.
Proper term for the material you can mark and then cut out for spray masking is "frisket", which might help in a search. You can make a frisket yourself with paper and repositional adhesive or buy clear plastic self-adhesive frisket material by the roll. The plastic will take any marker or pencil and is designed to be cleanly cut with a knife without damaging the underlying paint surface.
- Design & Build
- Construction Tips
- Great page for learning chassis fabrication
