Great Links
Hello Guys,
I made a bobo. I did a clean install of Windows and totally forgot to backup my bookmarks :bawling:
Would you guys mind sharing some of your favorite web sites for schematics? Particularly amps (ss and tube).
Also I had a link to some Asian web site with some really nice inexpensive DACs. Anyone have any such links???
Lawrence
lawbadman said:
Hello Guys,
Lawrence
Ouch. I feel for you.
So that others might avoid the same fate (and maybe you too, eventually, after you get your links re-populated), here's something I did, a few years ago: I exported my "Favorites" links to a file. Then I edited the file with Notepad or Wordpad and put HTML tags in (and did a little other "massaging"), so that it could function as a webpage, and then uploaded it to my ISP's server. Mine is way out of date, now, but, as an example, here it is: http://www.fullnet.com/~tomg/links.htm . There are some electronics links, there, too.
For those who still don't know how to do HTML "manually", it's easy. Just google for HTML Tutorial. Also, whenever you're on any webpage, you can always select View-->Source from your browser's menu, and it'll give you the HTML, which you can then edit, save, copy and paste, etc.
Here are a few links, for you, in no particular order (Well, they're actually (almost) in alphabetical order by the titles they had in one of my "Favorites" folders, which are not visible here. Sorry):
PART 1 OF 2:
http://www.fullnet.com/~tomg/gooteepc.htm
http://www.fullnet.com/~tomg/gooteesp.htm
http://groups.google.com (a goldmine!)
http://www.audioscientific.com/Circuits - Schematics & Tutorials_100.htm
http://www.muzique.com/lab/buffers.htm
http://www.fullnet.com/~tomg/gooteect.htm
http://www2.tech.purdue.edu/ecet/courses/eet257/
http://www2.tech.purdue.edu/ecet/courses/eet368/
http://omni.cc.purdue.edu/~tlrobert/302links.htm
http://ocw.mit.edu/index.html
http://www.rdmiddlebrook.com/D_OA_Rules&Tools/index.asp
http://platenspeler.com/background/attenuator/uk_attenuator_1.html
http://homepages.tcp.co.uk/~nroberts/atten.html
http://www.tangentsoft.net/elec/opamp-linreg.html
http://www.analog.com/library/analogDialogue/archives/39-05/op_amp_applications_handbook.html
http://www.hagtech.com/theory.html#choke
http://www.alw.audio.dsl.pipex.com/potentially_positive.htm
http://www.jhu.edu/~signals/
http://www.alldatasheet.com/
http://members.tripod.com/michaelgellis/tutorial.html
http://www.iop.org/EJ/abstract/0967-3334/21/1/301
http://depalma.pair.com/Analog/analog.html
http://www.analog.com/en/content/0,2886,773%5F%5F15010,00.html
http://eportal.apexmicrotech.com/mainsite/support/pages/app_notes.asp
http://www.maxim-ic.com/appnotes10.cfm/filter/category
http://rfic.eecs.berkeley.edu/~niknejad/asitic.html
http://www.users.dircon.co.uk/~wareing/3daudio.htm
http://www.pha.inecnet.cz/macura/buffer_en.html
http://www.audiodesignguide.com/
http://www.maxim-ic.com/solutions/audio_ics/app_notes.mvp
http://www.maxim-ic.com/appnotes.cfm/appnote_number/761/
http://www.dself.dsl.pipex.com/ampins/balanced/balanced.htm
http://www.edn.com/index.asp?layout=siteinfo&doc_id=127541&spacedesc=bestofdi_home&industryid=44217
http://www.eed.usv.ro/misc/mirrors/cc/circuits/circ0182.htm
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/info/comp/active/BiPolar/bpcur.html
http://www.eee.bham.ac.uk/collinst/walkthroughs/index.html
http://www.circuitcellar.com/library/toc.asp
http://www.falstad.com/circuit/directions.html
http://gprasad.150m.com/Electronics.html
http://www.circuitdb.com/browse.php
http://www.circuitrydesigns.com/index.htm
http://cmosedu.com/cmos1/book.htm
http://www.dspguru.com/comp.dsp/tricks/tricks.htm
http://ece-www.colorado.edu/~bart/book/book/contents.htm
http://bigbro.biophys.cornell.edu/documents/Temperature_Control/Duesing/tc2.html
http://www.allaboutcircuits.com/vol_6/chpt_5/14.html
http://www.dself.dsl.pipex.com/ampins/discrete/ef.htm
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/part1/page3.html
http://www.discovercircuits.com/S/s-peak.htm
http://sound.westhost.com/articles/distortion+fb.htm
http://www.diyhappy.com/
http://www.ultracad.com/article_outline.htm
http://eeshop.unl.edu/netsites.html
http://www.ecircuitcenter.com/
http://www.edn.com/archives/1995/052595/11di5.htm
http://www.ece.utexas.edu/~bevans/courses/ee313/resources.html
http://www.du.edu/~etuttle/electron/elecindx.htm
http://electronics-diy.com/
http://www.hobbyprojects.com/
http://www.elektor-electronics.co.uk
http://www.epcos.de/web/generator/W...e,templateId=render,locale=en,userGroup=.html
http://www.uni-bonn.de/~uzs159/expo_tutorial/index.html
http://www.fairchildsemi.com/
http://www.wenzel.com/documents/finesse.html
http://www.national.com/nationaledge/mar04/article.html
http://www.fundrace.org/neighbors.php
http://ee.wustl.edu/class/sp05/ese498/Electrical Engineering Design Reference Information.htm
http://www.signalintegrity.com/pubsIndex.htm#ground bounce
PART 2 OF 2:
http://www.elecdesign.com/Articles/Print.cfm?ArticleID=9018
http://www.irf.com/technical-info/anarchive.html
http://www.intersil.com/support/parametric_data.asp?x=datasheet
http://www.priorartdatabase.com/IPCOM_index/200504/?page=6
http://www.allaboutcircuits.com/vol_6/chpt_5/15.html
http://www.ibiblio.org/obp/electricCircuits/
http://www.beigebag.com/case_xfrmer_2.htm
http://www.free-ed.net/free-ed/Math/default.asp
http://emcesd.com/tt020100.htm
http://peufeu.free.fr/audio/memory/memory-4-circuits.html
http://www.microchip.com/stellent/i...SS_GET_PAGE&nodeId=1469&filter1=product&ln=en
http://www.messaggeri.it/xmisuretest.htm
http://www.musicfromouterspace.com/analogsynth/mmlogic.html
http://motorsinfo.com/steppingmotor/
http://nepp.nasa.gov/index_nasa.cfm/878/
http://www.reed-electronics.com/tmworld/article/CA314013
http://www.tpub.com/neets/
http://home.san.rr.com/nessengr/techdata/techindex.html
http://www.onsemi.com.cn/PowerSolutions/supportDoc.do?type=SelGuides&part=SG388/D
http://www.ecircuitcenter.com/Circuits/op_voff/op_voff.htm
http://dmoz.org/Science/Technology/Electronics/Design/
http://www.mentor.com/products/pcb/...bs/index.cfm&redirected=false&usemaster=false
http://www.geocities.com/CapeCanaveral/Lab/9643/TraceWidth.htm
http://www.marvin3m.com/connect/
http://www.swtpc.com/mholley/PopularElectronics/Popular_Electronics.htm
http://groups.google.com/group/sci....23737473549?lnk=st&q=&rnum=3#06e8323737473549
http://www.smpstech.com/mtblog/snubber_design.html
http://www.logwell.com/tech/components/resistor_values.html
http://www.powerlabs.org/
http://sdw.bgs.nu/a.html
http://www.electronics-tutorials.com/site-tree.htm
http://www.ridleyengineering.com/snubber.htm
http://homepages.which.net/~paul.hills/Emc/Snubbers.html
http://www.maxim-ic.com/appnotes.cfm/appnote_number/3835
http://archive.chipcenter.com/circuitcellar/november00/c1100rp58.htm
http://home.earthlink.net/~lenyr/index.html
http://www.st.com/stonline/stappl/p...PcStComTlHome.myComboChange&ptype=AN&keyword=
http://nov55.com/amr/cont.htm
http://www.tech-diy.com/
http://www.ecircuitcenter.com/Circuits/therm_ckt1/therm_ckt1.htm
http://www.hobbyprojects.com/T/temperature_compensation_circuits.html
http://www.rfcascade.com/tcomp.html
http://www.thatcorp.com/
http://www.national.com/nationaledge/nov04/adc_article.html
http://www.techrectory.com/Electronics2/directory/thermistor-circuit.html
http://scientific.thomson.com/
http://focus.ti.com/analog/docs/analogtechdoc.tsp?familyId=72&navSection=app_notes&templateId=3
http://www.eegeek.net/electronics/tutorials/tinnittutorial.htm
http://focus.ti.com/docs/training/traininghomepage.jhtml
http://experts.about.com/e/t/tr/Transistor.htm
http://www.kpsec.freeuk.com/trancirc.htm
http://hyperphysics.phy-astr.gsu.edu/HBASE/electronic/transwitch.html
http://www.elecdesign.com/Articles/Print.cfm?ArticleID=5032
http://home.flash.net/~evogel/
http://groups.google.com/group/sci....0960fab6110/7624368496a8ceaf#7624368496a8ceaf
http://www.usenet-replayer.com/groups/alt.binaries.schematics.electronic.html
http://www.maths.manchester.ac.uk/~bl/theses/cdenyer/intro.html
http://www.myhome.ch/mzingg/pcbstuff/tps/
http://www.national.com/rap/Story/0,1562,5,00.html
http://www.national.com/rap/Story/0,1562,4,00.html
http://www.zetex.com/3.0/3-8-1a.asp
Those ought to keep you busy for a while.
Enjoy!
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
