Heard of this cable? Curious about it? It is extraordinarily good. Ignore the price. I've used it exclusively in my system for about fifteen years, which is almost all Pass electronics. Before the Gotham, I had Audioquest Lapis (then top of the line) and then cables from FMS (a legendary cable here in New England). I don't have to tell you why I switched. I recently sent some to a friend who has the best system I've ever heard (outside a store) and who has very expensive cable from a very famous name. His response: "I need more of this wire".
If that's not enough, Pass Labs used Gotham Cable to connect the two halves of their $16,500 XP-30 pre-amp when it was used in mono. I'm guessing they didn't do it to cut costs.
I have three pairs of balanced interconnects built from Gotham Audio GAC-4/1 "star quad" microphone cable and Neutrik XLR connectors that need a new home. I'm selling them for less than the price of the connectors: $10 a pair. You couldn't build them yourself for less. I have two 2ft pairs and a 3ft pair. Easy way to try out this cable and see for yourself. Then you can buy the wire and make some yourself.
Shipping should be no more than $8.30 (in the US): Small flat rate box. We can probably do it for less.
