ryssen said:Does anyone have a schema for this one,just for fun to see how it´s constructed.
you just got one module? 😉
I'm very interested in hearing from you and others how this amp works out. Once I can afford it, wamt to build two 2.2SE stereo amps and an active crossover to biamp my speakers. I'd like to hear about experiences with alternate power supply designs, bigger transformers than recommended, etc - just to do it right the first time aorund.
Peter
I am going to use it to drive a subwoofer,havent tried it yet.
No.....Just asked incase someone had one.Dont think you will se a scheme of the zappulse modules
Re: Re: Got my Zap pulse 2.2SE modul today
I'm using an 800VA transformer instead of the 500VA they recommend. Of course I don't know if it makes any sonic difference but I think it sounds great 🙂
Michael.
See this thread 🙂pburke said:I'm very interested in hearing from you and others how this amp works out. Once I can afford it, wamt to build two 2.2SE stereo amps and an active crossover to biamp my speakers. I'd like to hear about experiences with alternate power supply designs, bigger transformers than recommended, etc - just to do it right the first time aorund.
Michael.
Nice amp!!!
1.How much uF are you using per module in the power supply.
2.Is the inductor hanging in the air.
3.Does the modules get hot under heavy operations,(high soundpressaure).
Thanks 🙂
I'm using the LC Audio Virtual 4 pole PSU which has 10x10000uF in total. I don't really understand the principle of the V4P "network" (some say it's a load of bull) but I don't think you can just divide that by 2 to get 50000uF.
I think it's more like 40000uF per channel.
Yes, the inductor is just hanging in the air.
The modules get warm but not hot. The base of the module is a thick plate of aluminium to which the MOSFETs are screwed and I have that just bolted to the bottom plate of my amp case and that's enough heatsinking.
Michael.
Michael.
- Digital Source
- Got my Zap pulse 2.2SE modul today
