Google Translate...finally found it
Moderator
Joined 2003
No offence to Mr. Pass...but this is real funny: :clown:
/Hugo - wonders how MuuHahahahahaha will be translated.😉
Re: Chinese whispers...
dhaen said:
Hugo,
What happens if you translate it back to English, using the same method?
Passage Of Nelson [ ] That and only Remotely Recorded: March 2001 Re: DIY-Pass-C$$Op with only of N-fets? Post #6 quotation: In is the beginning announced by Bernhard possible with has it only builds a DIY C$$Op with FETS of N? Completely possible, in the same way they employed with with the tubes. N of channel differential current pair is polarized by resistance or a current source of channel of N to the negative rail, and the drain of the right device (of door of feedback) led source (channel of N naturally) or a resistance. This drain by conduit also the door of a sectator of output of channel of N whose source connects to the negative rail a resistance or current source. This source is the output of the amplifier. Maintaining this circuit large positive excentré havewill have naturally, thus of if you want to direct couples it, must insert a voltage drop to you (could be a battery, for example) between the drain 2nd of pair of diff transistor and the door of the output device. If it is not clear, I am certain that one of our artistic readers will return a diagram to us.
Don't know if Bernhard will have good info on this... 😉
But this phrase remains rocksolid: "If it is not clear, I am certain that one of our artistic readers will return a diagram to us."
/Hugo :dead:
