Goodmans twin axiette
Hi, some further links:
http://www.linkwitzlab.com/
The following is in german but may be interesting to you though:
http://www.dipolplus.de/
I heard rumours that someone is working on an english
translation of that page ...
The speaker you are using seem to be vintage ?
Are those in a good condition ?
They look damned interesting !
Have you got further technical information about that driver ?
Please report on your ongoing project, i am curious ...
Cheers
Thanks, yes, they are vintage. Early/nid 1960's.
This is all the info i have
Posted: Tue Nov 25, 2008 8:23 pm Post subject:
found these specs for the axiette 8, dont know how different they will be for twin axiettes but all goodmans have done is add a parasitic tweeter.
frequency range 40-18,000
power handling 6 watts
fundamental resonance 65c/s
Flux density 13,500 gauss
Total flux 53,000 maxwells
Voice coil 1" diameter aluminium
Impendance 15/16 ohms
chassis diecast
overall diameter 21cm
overall depth 9.2cm
reflex enclosure volume 3000 cu.ins
baffle hole diameter 17.8cm
fixing holes 4, 19.4 pcd
nett weight 1.8 kg
They are in good condition. I had to repair one of the voice coils but they work fine now.
