Where can I get a proper stereo potentiometer with these specs:
Shaft length = 45-50mm
Shaft diameter = 6mm
Resistance = about 47Kohms
Taper = log
I've already bought some cheap potentiometers (here i Denmark, but the selection is very limited) but when I measured the resistance it shows 47.8 Kohms on one channel and 50.2 Kohms on the other channel, and on the one I've installed it is very irregular in the sound level.
David
Taper = log
David
Pots!
Hi Divad89,
Hasn't that famous Danish company DACT got anything to tempt you with??
DACT audio attenuators
Hi Divad89,
Noble AP25 have 50K log, cheap & good: 24$95 USD Michael Percy Audio, link:
http://www.percyaudio.com/Catalog.pdf
Better step: attenuators if you can afford.
