Good single rail opamps
I'm looking for another opamp to replace the philips TDA1308A I've fired on my soundcard (this is a headphone amp, but don't bother. It's fos a line output, not for headphones)
and the opamp is only powered with 0 and +5V, wich good opamps can I use for this?
so low voltage+single rail.
PS: can I use any +- rails opamp with single rail, and set +V to 1/2 Vcc and add a 1/2Vcc offset to the -V signal? (and off course, an output cap)
This should be a rail-to-rail OP
with good current output drive.
There are crertainly a lot of them around, modern.
Perhaps one of them video 50ohms line drivers.
See each OP amp manufacturers Selection guide
for example Linear Technology
or Burr-Brown
or National Semiconductors
or Philips
or Analog Devices
LT - Linear Technology OP amp Selector Guide
National Analog Amplifiers
halo - no problems the alternatives are out there! 😉 in modern shape ...
TI's selector guide is now online
in the past couple days TI just put their op-amp selector up as a 40+ page PDF -- also -- TI is now making knock-offs of some of the Linear chips, by the way. I just got in some LT1013's TI parts and they work identically as compared with the Linear Tech LT1013's.
www.analog.com www.linear.com www.ti.com
Not necessarily a good idea to just split the rail -- without careful attention to detail you will have the signal propogating itself back into the power supply., or the noise of the power supply propogating itself into the amplifier.
Bricolo said:
I know those websites
but does womeone know a good sounding single rail opamp?
One that is known to sound good
My OPamps doesn't make a sound - dead quiet.
If they did make sounds - I'd be totally crazy. 😀
I do not like Cables, that makes sounds either,
hope I never meet any of those....... :bawling: :bawling:
My music make sound from the speakers. 😉
/halo - probably an exception
- having dead quiet components - as far as his ears go 😎
He He - that was a good JOKE! Bricolo
Bricolo said:
try to put your ear closer to your opamp 😉
You make me laugh 🙂
Well, I guess I have to try,
put my OPamp inside my ear .......
I can use some wires to supply the power
to my ear
/halo - will test his OP amps - in the modern way
- by listening tests
Re: He He - that was a good JOKE! Bricolo
halojoy said:
You make me laugh 🙂
to my ear
new project: an opamp with an exponential horn 😀
Who need Tweeters & Woofers
Yes, of course!
Who need Woofers & Tweeters
when we have OP-amps that sounds (good)
Just make a good horn to get some
well-sounding
- OP-Speakers -
We can find out the T/S parameters by tests
by running tests on the different OP-amps
What would be the VAS of an OPA2134??
/halo - the new age in Audio is here !!!!!!! 😎
