Good Inexpensive Neodymium Tweeter?
Is anyone aware of good/inexpensive neodymium tweeters besides The Usual Suspects from Dayton?
I was thinking about taking another crack at a CBT or line array, and all of my sims indicate that you basically need a tweeter. (Please don't let this devolved into a discussion about why I don't need a tweeter lol)
Since a line array requires a LOT of tweeters, I'm looking for something, well, "good and inexpensive."
Another option I'm considering, is adding a metamaterial back chamber to each tweeter. A la the Kef speakers.
So if the housing is plastic, that's a bonus, I can saw the back off, similar to what I did with the SB Acoustics SB26.
the Vifa in the second post Zaph measured and assumed to be good is so-so in real life according some.
This one if the deeper layout is not a problem is better, some remove the FF for even better result.... https://hificompass.com/en/speakers/measurements/peerless/peerless-dx20bf00-04 . I use it in a monitor 3 ways Harbeth look above a 3" around 3k hz... it is ok to my dificult ears !
The Monacor has more efficienty if needed and ok above 2.5/3 k hz 18 to 24 dB.
https://www.lavocespeakers.com/single-product/?id=169
Thank you Scott! Just ordered two. Let's see what I can do with these.
Note that array's tend to "lift" the response on the low-end of the tweeters, and do so increasingly with the line length.. (..so maybe not that much for two of the slims stacked, but 6 or more of them stacked should increase the low-end of the drivers a fair bit - maybe enough at some length to result in an almost flat response between 2-12 kHz without correction.)
https://hificompass.com/en/catalog/speakers/tweeters/vifa-ot19nc00-04-19mm
ot19nc00-04
Small (19 mm), affordable and Neo...
