Hi to Everyone ! 🙂
I am very interested in knowing better compression drivers
So I am here to study 😀
I would be very grateful if anyone could give me some indications about manufacturers with decent products and good prices.
I already know Pyle
Moreover I would like to know which parameter I have to look for in the datasheets to evaluate the quality of a driver.😕
I am more interested in tweeter, i.e. drivers with 1,5-2" diaphragms
Is it true that the diaphragms can be replaced ??? 😱
So a compression driver is practically everlasting ???
Thank you so much indeed
Kind regards,😀
gino
I already know Pyle
Kind regards,😀
gino
I already know Pyle
B&C, EV, JBL, Ciare, Paudio... 🙂
Frequency response and distortion, (if available). TS parameters really don't tell you that much with CDs.
Those are getting to midrange territory, most people who use CDs for top end look at 1" diaphrams first.
Yes but they usually cost about half the price of the driver. 🙂
No problem. 🙂
thank you very much indeed for your reply !
but I understand that the famous brands you mention are top quality and consequently much more expensive than Pyle I am afraid
message received.
In your opinion the very best drivers on the market are also champions on this two parameters of freq response and distortion ?
No problem. 🙂
Actually I am looking for something able to cover the 1 to 15 kHz range
I have a weird idea in mind.
I would like to take the opportunity to explain a little.
In Italy there is a very high end manufacturer, this is the site
English Version
looking at his only speaker the dome drivers seem compression drivers used backward
I have friends who listened to this speaker and are telling me that it is exceptional
So my weird idea is to make something similar
But I would like to stick with just two ways even if this will cause a reduction of reproduced bandwidth (50 to 15.000 Hz will suffice)
Kind regards,
gino
If you can slightly alter your plans and find a good mid that will go up to about 2.2K, then for the price you can't beat the B&C DE10, a cracking little driver for the money.
Thank you for your kind suggestion
Actually I see a very good response curve
At this stage, I have just started asking for suggestion, I can alter pretty much everything 😀
I know that the midrange is the more critical range
I have not decided yet for a cone or a dome midrange driver.
I would like to go with just two ways but I understand the huge difficulties in this approach with only to drivers that must cover the all spectrum
There are commercial speakers doing this but usually they come very very expensive
Thank you very much again
Kind regards,
gino
Wonderful drivers but way out of my budget 😱
Pyle has models of very low price 🙄
My aim is just a decent sound. Nothing more 🙂
Thanks and regards,😀
gino
gino
Hello Gino,
I would recommend you the new Beyma CD10ND, it sound amazing.
But as I understand you want to pick a compression driver and take the back off, expose the diaphragm and bolt it on a LQS wave-guide ? (That is not going to work, because you are loosing the compression chamber!)
Than I would look for a titanium dome driver like Audax TW025A20.
Very good too, but the BMS diaphragm has no dome
http://www.thomann.de/gb/search_GK_palplkdp_BF_bms.html
You're in Italy. Shouldn't you be looking at FaitalPro and 18Sound?
Hi ! I will look at those brands you mention
I am trying to trace down the brands which offer the best Q/P ratio
Regards,
gino
Faital may be hard to beat, there.
Also look at Selenium from Brazil
Thank you for your suggestion !
Actually I live in same area of the factory
I will call them and check prices.
Kind regards,
gino
If you can slightly alter your plans and find a good mid that will go up to about 2.2K, then for the price you can't beat the B&C DE10, a cracking little driver for the money.Thank you for your kind suggestion
Kind regards,
gino
If you've got the money, the B&C DCM50 should be an awesome midrange. You'll need a really big horn to go with it though.
- Live Sound
- PA Systems
- Good brand for compression drivers (i.e. high Q/P ratio)
