• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
GIFTS!! NOS stuff -russian capacitors, Siemens MKVs, chokes, power resistors.
I'm giving away many of my old stock capacitors and some other stuff. Feel free to pick any choice you want. 😀 Keep in mind that I might add some few more things in the coming days.
1. 100W Tesla 62R with adjustment - 8 pcs. Never used
attachment.php
2. Pair of ITT capacitor (MKV construction like) PP in oil capacitors 10uF 660VAC. Never used.
attachment.php
3. 8uF * 4pcs (they are 3 on the photo, but I found a 4th) and a pair of 5uF Siemens MKV 660VAC. Used for approx 200h on a tube power supply
attachment.php
4. Pair of two russian KBG capacitors (PIO) with same ratings (10uF 200V), but different manufacture dates. Never used
attachment.php
5. These where 10uF MGBP if I remember correctly. I don't remember the breakdown voltage. I removed their steel can. They sound a bit better
without it. Never used before and after the mod.
attachment.php
6. 4pcs KBG-MN 0,5uF 600V and 2pcs KBP-F 0,47uF 250V. Never used
attachment.php
7. Two tube power supply chokes rated 10H at 250mA. Used for approx 300h in a tube PSU
attachment.php
8. Lot of small russian caps. 4pcs of K40U9 at 0,1uF/1000V ; 2pcs K42-U2 0,22uF 1000V ; 2 pcs MGBP 3,9uF 200V ; 5 pcs KBG 0,1uF 600V ; 4pcs K73-16 2,2uF 250V and 2 pcs 4,7uF 250V ; 2 pcs BMT 0,1uF 1500V ; Bosch MP 0,47uF 400VAC. Some are used, some are not
attachment.php
Best regards,
Alexander.
