General question for Ground zero GZPA 1.4k,1.8k a.s.o.
Hello, the last time i had a few difficultys with this type of amps.
Repaired the outputs... On some amps, it was also neccesary to change the irs 21844s.. Checked everything, complete new batch of mosfets. All parts from mouser. Tested the gate-source with a cap, everything looks fine. Final check of the amps also ok.. Customer happy, everything works, even under full load for a longer time... After a few days, or a week, the amp goes in protect, with small load, or only on, with no music playing..
Found two output mosfest short, one highside, one low side from the same bank. Couldnt find anything wrong...
Is there something, what i dont see, maybe somebody can give me a hint, where or what to look...
