GC SuperSymmetry part IV
The one and only
Joined 2001
Then there are those who only want Chips in their amp.
www.passlabs.com/np/GC-SS-4a.pdf
In this case the output stage consists of both series and parallel
chip amps. The voltage sources you see introduce differential
DC offset between the two parallel chip amps, which allows
a DC bias current for the amps which can be set arbitrarily.
This DC bias is not seen by the load which sits beween the
output resistors. The damping factor remains high, as it is
enclosed by the GC input pair.
I leave it to you to decide what constitutes an acceptable
bias current for the chip amps.
Like the other versions, note the chip amps each having their
own local (nested if you like) feedback loops. Adjusting these
loops will give a wide range of performance/stability character.
As with version 3, we can easily arrange to invert the input
pin polarities of the chip amps, but that would be a trivial
variation after the first example.
There will be a prize for the first person to find a mistake
in any of the four.
Pepper:
I see that the four output stage chips of 4a are utilized only with their half capacity at maximum. If so, 2a or 3a are more intersting potential projects?
And... and if it is full of emptiness inside his brain, he would speak out very much and long. 😎
jh6you said:
Confused: The input stage chips of 4a should have -/+, not +/-. I'm really confused. And... and I clearly see the complexity inside Nelson's brain while he speaks out so simple. 🙂
No, I believe that's correct. We just keep flipping the polarities
until it comes out. 😎
inverting topology
jh6you said:
Red.hot.chilly.pepper:
The 4 inside should have the flipped polarities. Otherwise, I give up this project...??? Because of :whacko: .........................
You need not give up.
As the 2nd OPA gets its inputsignal from the supply shunt resistor
of the first one the phase is 180°.
Imagine driving OPA1 with positive signal -> output gets positive
thus drawing current from PSU -> this in turn leads to more
voltage across that shunt -> this again leads to negative voltage
at the capacitor coupled input of the 2nd OPA -> Bingo!
Uli
:nod: :nod: :nod:
Flipping.Polarity:
Yeas, I was right !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
There were problem, but with the polarities of my head.
Now, my head polarities came back to the original, and accordingly I can clearly see the polarities that all are correct.
:usd: :usd: :usd:
