[Closed] GB UP/UGS All Inclusive PCBs
I'm starting a new PCBs GB for Cheff's UP amp and UGS "All Inclusive". The GB has just started on the french forum HCFR.
There are 2 kits : first one with every double sided pcbs, second one with the remaining ones.
Closed, PCBs in production. I will received them around 5th october.
Double-sided kit :
UP (everything) :
-Amp boards (x2)
-Small caps PSU (x2)
-Trigger (x1)
-Vu (x1)
UGS AI :
-UGS (x2)
-Motherboards (right and left)
-µC (x1)
-Logic PSU (x1)
-Triggers (input and output)
-Subwoofer (x1)
-Programmer (x1)
Finishing : 70um copper, 1.6mm thick, HASL, BLACK soldermask
Single-sided kit:
-UGS AI PSU board
-UGS AI XLR/RCA boards (right and left)
Finishing : 35um copper, 1.6mm thick, HASL, BLACK soldermask
It is not possible to order just one board from one kit.
Kits will be delivered on panels, as follows :
Single-sided kit is another panel.
Depanelization should be done by yourself. Minimum space between 2 boards is 200mil (4.5mm). The whole board is around 15"*19" (38*48cm).
No V-cutting/Tab routing etc.
Aimed prices:
D kit : 5 orders - 75€ + shipping
...........10 orders - 65€ + shipping
S kit : 5 orders - 35€ + shipping
..........10 orders - 20€ + shipping
Shipping is from France.
Faame - 2 kits - No problems
Cacahuete (hcfr) - 2 kits - OK
Alexoni (hcfr) - 2 kits - OK
Patroussea (hcfr) - 1 kit - OK
Powerdoc (hcfr) - 1 kit - OK
Jacek_k_wawa (diyaudio) - 1 kit - OK
Potepuh (diyaudio) - 1 kit - OK
Thank's,
Faame
Double-sided kit :
UP (everything) :
-Amp boards (x2)
-Trigger (x1)
-Vu (x1)
UGS AI :
-UGS (x2)
-µC (x1)
-Logic PSU (x1)
-Subwoofer (x1)
-Programmer (x1)
Single-sided kit:
-UGS AI PSU board
Aimed prices:
Thank's,
Faame
How easy to 'depanelization'? Just break apart the boards or need any specific tool?
Specs for the board? How many mm and oz?
Rol
Rol
Depanelization should not be hard. A saw is ok. A dremel might be a better choice. There is, in my own opinion, enough space to feel confident. Some extra care is still better obviously 🙂 Just take a piece of paper, draw 2 lines with 4.5mm space between each, you'll see it is OK.
Boards are 1.6mm thick, 2 oz (75 µm) copper, FR4 TG140.
Here is the schematic for the UGS All Inclusive and the 2 missing PCBs:
http://psykok.dyndns.org/diy/preamp_ugs/Atours/Atours.pdf
http://psykok.dyndns.org/diy/preamp_ugs/Atours/AlimSecteur.pdf
http://psykok.dyndns.org/diy/preamp_ugs/Atours/CartesXLRRCA.pdf
A French fellow noticed I forgot one PCB to program the Atmega64 on the µC board. It will be added soon 🙂 (price unchanged)
I would be interested on the power amp boars and the protection.If someone just need the preamplifier we could share the set.
Please keep in your mind if someone only interested on the preamp set and let me know.
Thank you
Greetings Gabor
Thank you
Greetings Gabor
Well jacek_k_wawa confirms 1 order.
If there is one more order then we will be 10. Price for ten is finally 67€ and 23€.
Shipping in Europe is 20€.
Group buy closed !
If you want to get it in, please send me a pm before midnight local time in Paris.
HI, I know its a long shot, but does anyone have a spare set of boards they want to sell? Please PM me.
- Group Buys
- GB UP/UGS All Inclusive PCBs
