GB: Singing Bush Power Supply PCB Kit
Joined 2018
PCB Kit to make the Singing Bush SIT amplifier. Kit includes 2 Power Supply PCBs, 2 CL60/AC Cap PCBs, and 2 Bridge Rectifier / Snubber PCBs.
The power supply PCB is set up for 50mm diameter Cornell Dubilier Electronics (CDE) 5-pin 382LX/383LX series capacitors.
It has positions for 2 LEDs: 1 for on-board, and one for a front panel LED.
It can be configured as CRC or CLC.
PCB Connections can be hardwired or use 5.08mm quick disconnect spades (e.g. Molex 19708-4013 or similar)
All PCBs are designed to fit on the 10x10mm grid in ModuShop chassis bottom plates.
$25 + Shipping. 4 kits available now. Can make another GB batch based on interest.
PM me, or buy direct here:
Singing Bush Power Supply PCB Kit | Etsy
marlin97- 1 set
AlexRivera- 1 set
mordikai- 2 sets
sampsonite - 1 set
Redarc12-1 set
asphalt - 2 sets
14 sets just arrived. accounting for the above, that leaves 6 sets remaining. Everyone above, please send me a PM with your shipping info and paypal email address.
Thanks Randy, I also received an order today with yours posted from the west coast of the US and it only took 10 days - so it seems to take about as long to get from your location to LA or SF before it gets on a flight to Oz.
Have my caps ordered from Digikey - so I am good for those.
