I'm looking for a schematic for a Garnet Tripper PA head. It's a four channel mixer with a 12AX7 and a 12AU7 and a pair of 6V6's. The model is T90PA. Each channel is wired to a separate volume pot and then summed prior to the first gain stage.
It's all point to point and I could draw one up but I don't know if anyone has been in here and what they've done.
Cheers
Cheers
I should have mentioned that I've already searched on google and through forums. The link you sent does not contain the schematic I'm looking for. I'm hoping someone happens to have it themselves, because it's not yet on the internet.
It should be close. Close enough to reverse engineer.
Gar was known foe making changes on the fly, so even if you find the exact model, chances are it will be different anyway.
