G-class with LM3886?
Hello!
Have you seen any G-class amplifiers realised using LM3886 amplifier chip? I'm building an active loudspeaker system with surrounds so I need efficient amplifiers to be able to cope with the heat from 12 channels. The one G-class amplifier I know is done with TDA7294 http://www.st.com/stonline/books/pdf/docs/1057.pdf but somehow I feel that LM3886 might perform equally well or even better since LM3886 seems to have better distortion graphs, open loop gain and PSRR.
Please share your wisdom 🙂
-Elias
Thanks for the link, I've examined the patent. Yes, it shows the principle of operation of how to do G-class with chip amplifiers like LM3886, but like in all the patents they don't show any really working circuits. I don't think the presented configuration is stable if copied directly without any extra stabilising components (whatever those might be in this case). That's why I'm thinking more like a 'feedforward G-class chip amplifier' where the control for the higher supply voltage transistors is fed from the input and not from the output.
One performance limiting factor in G-class is the nonlinearities of the output conductance of the transistors, the same property wrehe the Early effect comes from. This might be an issue if G-class is realised with e.g. LM3886 where all the transistor stages are experiencing the voltage variations of the supply lines. In this regard, the TDA7294 (and likes) might perform better.
However, I can not be sure before I've build and measured a prototype, which is hopefully going to happen in coming weeks.
-Elias
