G.A.S. Ampzilla, Original Kit Version - works
Well, I really don't use this amp so it's time to move it on to someone who will appreciate it more than I.
I rescued it from a music store going out of business. It was dead when I acquired it, so I pulled it apart and made some repairs to it, mostly bad solder joints and replaced all the fuses inside. The amplifier works, but it's going to need some assistance. First and foremost, the RCA inputs need to be replaced. The original ones use ceramic insulators which are cracked and no longer functioning well. The other issue is the left side meter does not work. If I jump the right meter to left it functions, so the meter itself is good, it looks like the board that drives the meter may need some help. Looks like a pretty simple circuit but I don't have time to play with it. One of the speaker terminals is missing its plastic nut, but still works.
You'll also notice the case is scuffed up and could use some help. Side panels are badly chipped but not dented, you'll also notice the right meter has a crack in the acrylic. I thought it was a scratch, but I was never able to polish it out.
This machine is 100% original. No modifications, no changes, no rebuild, it is bone stock. The meter switches on the front do work.
PM me if you need any more information I'll be happy to answer any questions. Shipping for this is probably gonna be about $100+ as it weighs 60 pounds.
I'm asking $800 O.B.O for it, substantially less than I can probably get for on eBay, but I'd rather have someone who could appreciate it get it.
Reactions: Pano
