Evening all,
I have just finished installing fusion fa123 amps to my 3 way speakers and dialled in basic crossovers. However, the left channel (slave amp) keeps going in to protection mode. The flashing light indicates a high temp. After I have switched them both off for a while and they have cooled down I find that the slave amp has reset the input setting to Auto and the volume to -96db. However, after switching the input back to SP/DIF and adjusting the volume the best I can achieve is a broken signal.
Any ideas?
Any ideas?
You don't need to open new threads for every questions about your Fusinonamps. Imo better option is to write to the main Fusionamp thread here, I assuming there is much more follower and you may receive answers much easier there:
The New Hypex Fusion Plate amps
