fuse
Disabled Account
Joined 2002
i have a DJ amp 800W X1 (4 Ohm) (8 tr' of 2SC5198-2Sa1941)
in my amp dont have a fuse or protection...
i want to put a fuse for protection.... how much (A) fuse i needed for speaker out??
and how much (A) fuse i needed for power supply in my amp??
(48V AC 600VA)
Hi DJ
To calculate the correct speaker fuse value, we can use the equation P = I^2*R, which is rearranged to I = sqrt(P/R). Thus, a 800W 4 ohm speaker should draw an RMS current of about 14.1A. A 15-18A speaker line fuse would therefore be suitable.
For a symmetrical 48V supply with a 600VA transformer, ignoring any rectifier losses, a maximum current of about 6.25A per rail can be supplied. A 6.3A slow blow fuse in each rail would be about right - maybe a 10A if you experience any nuisance blowing. Make sure you place the fuse in the supply line _after_ the reservoir capacitors.
As a side note, the fact that your "800W" amp only has a 600VA transformer and absolutely no output protection, shows it is a poor design. Like I say, consider proper PA equipment next time. 🙄
Hope I've answered your query,
Tim.
"can i make him stronger....?"
Not easily. The whole design must be considered, you cannot just increase the capacity of the transformer and change the output transistors. If you need more power I wouldn't waste time and money on this amp - try a different design.
Tim.
