I had some water leak in over the top of my fuse box under the drivers footwell. Car is Laguna MKII.
I took it out and found some corrosion and cleaned it, but one pin has broken at the base se needs replacing. Can anybody help me find the right part? I have accounts with Farnell and RS Components if that helps.
It measures:
17mm Long (approx, since it broke)
1.5mm Wide
1mm Thick
Here is a picture.
It measures:
1.5mm Wide
1mm Thick
Here is a picture.
I bought a used fuse box on eBay for £14 delivered. Given there was obvious corrosion from water I guess it is better just to replace it. Hopefully the used one will not be corroded too as water coming in that place is common if the drainage holes get full of muck!
I'd probably pay £5 just for a bag of pins, so a whole replacement box seems worthwhile.
