For Sale FSUK - Mark Audio Alpair 7MS (Single)
Things you have for sale.
Clearing some odds and ends before the baby splashdown.
Mark Audio Alpair 7MS 4" driver. An exceptional speaker driver. Unfortunately I damaged the other one so have this one taking up space. Perfect for someone looking to complete a surround set up. You are welcome to the damaged driver if you want. With Original box and rubber gasket installed.
It has never been abused and only ever used crossed over at 100hz with a sub.
Cheapest in the UK is £120
£25 POSTED TO UK.
https://www.markaudio.com/online_shop/alpair/alpair-7-ms/
RE 7.2 Ohm
FS 74.724
SD 50.270 cm²
VAS 4.968 L
CMS 1.384m M/N
MMD 3.072 m KG
MMS 3.277 g
BL 3.859 TM
QMS 2.350
QES 0.744
QTS .565
LE 124.716 uH
SPL 86.324db
X MAX 4.5mm one way
POWER (NOMINAL) 15Watts
