Hi.I have high quality 2.2uf 400v dc wima mkp10 capacitors.Wima mkp10 capacitors have better sound than wima mkp4
Here is the test link.You can see how a good capacitor it is.Very good quality sound for its price.
Humble Homemade Hifi
WIMA MKP 10 100VDC – 10% tolerance
Technical specifications: “Pulse capacitor. The construction principle of the series WIMA MKP 10 consists of a non-metallized dielectric film and an carrier film metallized on both sides acting as electrode. Thanks to the metallization on both sides, the electrical conductivity is considerably improved and the contact surface between the electrodes and the schoopage layer is doubled. This results in better contact and allows for high current and pulse loading capability. The properties of metallized capacitors such as excellent self-healing and high volume capacitance remain unchanged.”
Sound: With the WIMA MKP 10 you get a neutral, smooth and well balanced capacitor. For this price range the amount of transparency is quite reasonable and overall the MKP 10 is pleasant to listen to. Compared to the similar shaped and sized Mundorf RXF the presentation is more forward and a fraction less clear. But never the less it has good overall sound qualities. Don't forget to give it some time to burn-in. Fresh out of the box they sound “restricted” and dynamics are limited. After several weeks of use the open-up.
Verdict: 8
Shipping is 3.99$ for 2 pieces.Or 4.99$ for any pieces(4-8-16-32 etc...)
Thank you!
Verdict: 8
Thank you!
And also you can visit my ebay audio store for many of hi end component needs!
Paradise of Hi-end audio components items - Get great deals on items on eBay Stores!
This is the picture of Wima 2.2uf 400v.Also other Wima mkp10 capacitors are available.
0.1uf 160v dc
0.22uf 250vdc %5
0.22uf 630vdc
0.22uf 1000vdc
10nf 630vdc
1uf 400vdc %10
All of them geniune parts in their boxes.
Thank you!
0.1uf 160v dc
0.22uf 250vdc %5
0.22uf 630vdc
0.22uf 1000vdc
10nf 630vdc
1uf 400vdc %10
Thank you!
Hello,
Just sent you a question on ebay about four Wima MKP10 2.2 uF and two 4.7 uF.
Need those for my tube preamp (2 x 2.2 uF + 2 x 4.7 uF) and for my tripath class-D amp (2 x 2.2 uF).
Thank you,
Thank you,
Hi.I do not have 4.7uf wima.I have ero mkc 4,7uf 63v.They are excellent capacitors too.Just buy what you want(little capacitors) I can make shipping only 4.99$.Thank you!
- Vendor's Bazaar
- FS: Wima mkp10 2.2uf 400v dc capacitors 1.99$ each!
