• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FS: Various items
I have a very very nice pair of Boston Acoustics T830 (Series II with the binding posts in back, not the bottom), 3-way mini-tower speakers. Cabinets are in very good shape. All drivers work and sound amazing. Woofers were just refoamed about 2 months ago with the correct filleted surrounds. Also have the owners manual, warranty card, etc.
The ONLY issue... The grill cloth is a little ripped up. Replacing the cloth is not easy on these because the frames are plastic welded. Not impossible, but challenging.
Because of this issue, pricing at $100 for the pair.
If you want the grills looking perfect again, $150.
Local MA/NH.
If you have never heard a T series, especially this small T830, you are missing out. They are surprisingly good and sound way better than many other speakers I have auditioned. Bass is deep and taught. High end is crystalline. The CFT3 polymer tweeter is one of the best I have heard.
Auditions welcome.
Images
FS: Klipsch KG4, Black, Very Nice
I have a pair of Klipsch KG4 speakers with the 3" risers that I need to part with. Wifey doesn't like them. These speakers are incredibly efficient. All drivers work. All rubber surrounds. The rear firing PR is also perfect.
Black finish has some worn spots, but no water marks an no busted corners. Remember, these are 25 yr old speakers. Could painted black again, or sanded and stained.
Grills have original cloth which is in great shape, albeit a little dusty. I vac'd, but didn't want to push them too far.
Pictures coming soon. Local to MA/NH. ( I guess they *could* be shipped if someone wanted them enough. )
Price highly negotiable! $165 OBO for a great sounding "classic" Klipsch from 1990.
FS: Morel PP300, 12" DVC Subwoofer, Professional High dB
I have a very good sounding Morel PP300 dual voice coil subwoofer. This very unique speaker uses Morel's multi-magnet system combined with two separate 3" Hexatech alum former and alum hexagonal profile voice coils. Thick paper cone and coated, pleated cloth surround. These puppies can move some air! And the shallow magnet structure means it can be used in a car application as well. 300 w RMS power handling.
For use in free-air applications, or a 1.5 to 2.5 cu fu enclosure, typically ported or with at least 2 Variovents. Morel used the Variovent concept a lot on their pro speakers.
Possibly use for an H-frame build???
This one sounds great on either voice coil. $75 SHIPPED
FS: Morel MW-220 8" Woofers, one NIB, one used
I have a new, in the box, MW-220 Morel 8" woofer. Rubber long throw surround. For use in a 0.7 to 1.4 cu.ft. sealed enclosure. I have also seen/heard these in a variovent enclosure of about the same size and used as a subwoofer.
High quality Morel Hexatech 3" alum voice coil and alum former. Shallow magnet.
$50 + shipping.
I also have a used MW-220 that works perfectly. Will add for another $20 so you can have a pair. Tested and works great. Dust caps are not pushed in.
FS: Klipsch 10" Subwoofer, K-1049-K
Selling a perfectly functioning and tested Klipsch K-1049-K 10" subwoofer driver from a KSW-150. Surround in good shape. Good to have as a backup replacement or DIY.
$30 SHIPPED
A very capable driver.
FS: Renaissance Audio WR-12 Subwoofer, NOS
Selling a very unique Renaissance Audio car subwoofer, the WR-12. This is the second most powerful sub they make aside from the Cannon. Go to the Renaissance Audio web site to see more information. This speaker tests out perfectly and sounds amazing. These were made by Eminence, a major brand in speakers, for Renaissance as a custom design. The Eminence chassis and magnet assembly are unmistakable and the code is 67.
These retail for $400 each.
$100 SHIPPED CONUS!!
Renaissance Audio Group
Mounting Depth: 5.25"
Power Handling (RMS): 300 Watts
Cone Material: Specially Treated Paper
Frequency Response: 28-300 Hz
Resonant Frequency (Fs): 29.85 Hz
Sensitivity: 93.5 dB
DC Resistance (Re): 3.39 Ohm
Mechanical Q (Qms): 9.78
Total Q (Qt): 0.28
Equivalne Cas Air Load (Vas): 156.71 liters
Xmax: 5.50 mm
Le: 0.96 mH
BL: 12.38 T*m
Mms: 68.75 grams
Cms: 0.4135 mm/N
SD: 519.45 sq. cm
Designed to work in a ported box, approx 1.7 cu.ft. (59-61 liters depending on what software you use) 3.3" wide and 4.2" long port. Fb of 39 Hz
FS: Morel Renaissanse MSW-12.1 Subwoofers, NOS
I have some excellent quality, top of the line, Morel USA Renaissance MSW-12.1 subwoofers. These are 8 ohm subwoofers and are meant for a large ported enclosure. These sell new from Renaissance for $200 each. Let me know how many you need. These are all brand new, never used, "new old stock" (NOS).
Asking $60 SHIPPED each, or TEN FOR $500.
Or make me an offer. I need workshop space!!
Please see the spec sheet here:
http://www.renaudio.com/Docs/Woofers/MSW-12.1.doc
MSW-12.1 Additional Information:
SPECIFICATIONS
Power Handling (RMS) 400 W
Transient Power Handling 1,500 watts
Sensitivity SPL @ 1watt 90.8 dB
Nominal Impedance 8 Ω
Resonant Frequency Fs 23.3 Hz
VOICE COIL
Voice Coil Height 30mm
DC Resistance Revc 6.2 Ω
Zmax @ F0 Z0 217.0 Ω
Net Weight 6.36 kg (14 lbs)
FS: Yamaha RX-V2095 Receiver, Lots of bells + whistles !
The hits keep coming!!
I'm selling a nearly perfect Yamaha RX-V2095. TOTL surround receiver from about 10 years ago. Pre-HDMI and older surround modes, but tons of functionality. And it sounds so so so clean. In stereo mode, it will contend with some very expensive amps/separates.
Comes with original remote, which is massive and even lights up! Also includes owners manual and separate remote manual.
Nary a scratch, but the remote has some finger smudges.
Asking $175 + shipping
Keep in mind this receiver weighs about 35 lbs and is huge.
Pictures!
Notice the Multi-channel I/O, 2 center channels outs, and TOSLINK I/O. Could use this as a 2 channel pre, Multi channel pre, 2 channel amp, Multi channel amp, DAC, etc... And the sound fields are totally cool. No one does sound fields like this any more.
Someone buy it before I keep it!
