Subbu Dac V3 finished with Gary B modification; Subbu PSU ; JG Buffer; PSU +/- 15Vcc for JG Buffer; USB - SPDIF CM6631A; Chassis Hammond 1455N2201BK.
* Subbu DAC V3 with Gary B modification - 100 euro;
* JG Buffer + PSU +/-15Vcc - 70 euro;
* USB - SPDIF CM6631A - 30 euro;
* Chassis Hammond 1455N2201BK - 25 euro.
All parts are assembled on Chassis Hammond 1455N2201BK, the sound is great but I have to go with ES9018 and I have to sell the Subbu DAC V3.
I will ask 250 euro including shipping to Europe and payment method - only PayPal.
A will attached some pictures from the execution ...
The pictures are from first building, there are not even the Gary B modification, not JG Buffer, not PSU for JG Buffer. I will attached some recent pictures on the evening.
Best regards,
Cristi.
Best regards,
Cristi.
Ok, last modification: JG Buffer + PSU sold.
Subbu DAC V3 finished containing:
- DAC PCB assembled, PSU PCB assembled and Gary B modification on the DAC PCB;
- USB - SPDIF CM6631A;
- Chassis Hammond 1455N2201BK.
Everything 100% functionaly, the CM6631A has the latest firmware update and buyer will receive the driver for this device.
Price (not sold separately): 180 euro including shipping to Europe and payment method PayPal only.
Subbu Dac V3 finished with Gary B modification; Subbu PSU ; USB - SPDIF CM6631A; Chassis Hammond 1455N2201BK.
180 euro including shipping to Europe, PayPal only...
I have enough V3's so I won't buy it (very nice build though). Did you already compare to ES9018 ? Members have emailed me that there are quite some branded ES9018 DACs out there that sound less good than their V3. Should not be like that I guess.
GaryB is a guy that built some beta V3 and some final version V3 DACs. Gary experimented a lot and made modifications regarding cap types and values which improve the DAC performance.
And:
C17 - 1uf X7R MLCC Ceramic capacitor (many possible vendors)
C22 - 470uf 6.3v Panasonic SEPC 6SEPC470
C32 - 1uf Wima MKS2 with 2.5mm lead spacing - MKS0B041000F00KSSD
C35 - you should use either C32 or C35, but not both. If you want to experiment with larger values of Wima MKS2 that only come with 5mm lead spacing then use the C35 location instead of C32. You should not use a value >4.7uf or the sound gets worse.
C4 - 1uf Wima MKS2 with 5mm lead spacing - MKS2-1/50/10 or MKS2-1/63/5T or MKS2C041001F00KSSD
