FS: Rotel RDD980 w/remote CDM9
Rotel RDD 980 transport with Philips CDM9 (little sister of the CDM9pro) Arguably the CDM9 is the end of the line for the higher quality Philips transports. You will need your own DAC!
Just reduced to $199 plus actual cost of shipping and I will eat PP.
All functions work as designed including optical. Had to press ear ONTO the chassis to actually hear it was running. All functions work via remote as well, except tray does not open which is by design . Tray will close when play is pressed.
This Rotel is a back up that never needed to be used as a backup and has been in storage in my closet. I of course have used it a few times and I ordered the replacement remote (Rotel RR924)for it probably 10yrs ago
Audiogon bluebook says new retail was $700. Rotel's entry level higher quality in response to plethora of transports being built back then.
replaced door belt quite awhile ago. Readily available still.
Will be well packed as is my obsession --see my fb on Audiogon w/same user name as here. buyer pays for actual cost of shipping and I will eat PP. FYI--if you can take delivery at a business it will cost less for shipping via Fedex ground rather than home delivery rate. I use my account to calculate cost. If pics do not upload see my listing on US Audio Mart.
