SOLD!
Have this little GEM for sale! Pioneer Premier DEX-P9 SQ headunit. Copper plated chassis, Aluminum faceplate, (3) Gold plated Hi-Volt RCA outputs, SAT ready, Optical out.
Truly a high end audiophile headunit. These sold for $1200 new! This is designed to be coupled with a DEQ-9 Equalizer through the optical out, allowing you to control all DEQ settings from the headunit. Or can be paired with any aftermarket EQ through RCA connections. (Does not have on-board EQ). Comes with manual and remote (which is essential for almost every feature of this unit).
You can also use Pioneer's add-on USB and/or Bluetooth modules to make this unit just as up to date as anything else out there!
Tested and works great! However I am missing the power plug. It is readily available and in-stock from Pioneer. The unit has a small dent in the top of the faceplate and a nick at the bottom near the Premier logo. Otherwise in very good condition.
Please ask any questions. Will send any picture you'd like upon request if needed.
$250.00 (Paypal) Shipped to the lower 48 states. No trades sorry.
