FS: Pioneer 12" Woofers (4)
New $90/ea, Mine $90/pr or $160/all4. You pay shipping.
Clean, authoritative, deep to maybe 35 depending on tuning.
I wouldn't use above 700 or so, nasty peak at 1k but smooth below that.
Never abused, Hi-Fi only, but you can seriously boogie with all 4.
Specs below pix.
DM to ralph james at bell south dot net. (remove spaces)
Pioneer A30IR50-51F Specifications:
• Power handling: 150 watts RMS/210 watts max
• Voice coil diameter: 2-1/2"
• Impedance: 8 ohms
• Frequency response: 19-5,000 Hz
• Magnet weight: 50 oz..
• SPL: 91 dB 1W/1m
• Vas: 11.91 cu. ft.
• Xmax: 3.1 mm
• Qms: 4.37
• Qes: 0.27
• Qts: 0.25
• Fs: 19 Hz
• Net weight: 10 lbs.
• Manufacturer model number: A30IR50-51F
• Dimensions: Overall diameter: 12-1/8", Cutout diameter: 10-7/8", Depth: 5-1/2", Magnet diameter: 6-1/4", Magnet height: 2".
