Hello,
Location: Chicago. I am willing to sell or trade. However, I only need an amplifier chassis at this point. The chassis needs a height between 2.25" - 3". The other needed dimensions are roughly 8" x 11". I am open to many chassis ideas, including all things weird. The chassis needs to be strong as there will be a fair bit of weight sitting on it; aluminum is probably not ideal.
So here's what I have:
(2) Wild Burro Betsy K - opened box, tested briefly for functionality
(2) Vistaton FRS8-8 - opened box, never tested
(1) lot of parts: (1) DAMAGED 2U UMS heatsinks 8 hole pattern drilled and tapped with M3 threads (the threads on one hole were stripped), (1) NEW TPA3125 integrated circuit, (4) NEW Parts Express gold extra long binding posts (091-340), (2) NEW Parts Express dual gold binding posts (091-335), (1) NEW unknown 1/4" headphone jack, (1) NEW NKK S339R dpdt toggle switch, (1) NEW Jameco MTS-2 dpdt mini toggle switch with flat actuator, (1) NEW unknown dpdt mini toggle switch with round actuator, (1) NEW unknown XLR connector, (2) NEW Dynakit RCA-1-M retro plastic jacks, (1) 3+1 terminal lug, (1) USED Bourns 50k potentiometer (used for a single test), (1) NEW Corcom 10CE1 power inlet with rocker switch, (1) NEW Bourns 3386 trimmer, (2) NEW red LEDs, and Random high quality resistors and capacitors
I do have a pair of open box (tested) standard Betsy's. I'm not inclined to unload those right now.
