FS: Onkyo SE-200PCI sound card
I have two card to sell. Driver support has been dropped for Windows 10, so unfortunately I can no longer make use of them. Driver support Windows 2000 to 8.1 (64 bit), inclusive.
One card comes with the breakout dongle only. The other card is boxed with all accessories.
Asking $80/90, free worldwide shipping.
Cards are PCI bus, Via EnvyHT codec Wolfson 8740 DAC (115 dB, 24/192 playback), Onkyo VLSC output stage with dual mono analog output stage. Excellent power supply filtering.
RCA line level output, optical in, optical out, 7.1 surround out and recording RCA input (up to 26/96 only) via the breakout dongle.
Details here.
Download drivers here.
That was probably me. I had three originally, these are my last two. Obviously, I really like it... too bad the drivers are not compatible with Windows 10.
It's an odd bug. Maybe the 32 bit OS version will work in Windows 10, I don't know. I had repeated problems with Win 10 64 bit though. With the built-in Windows drivers for VIA EnvyHT codec the card does basically function ... but the Onkyo drivers are needed to access the switch that allows the card to be put into PCM mode where you can select the output sampling rate. It is stuck at 48 kHz otherwise.
