Built from a kit, the ST-NG is a stereo tube power amplifier based on the Dynaco ST-35. 17.5W/ch. The power supply comprises the high voltage, regulated dual bias adjustment, and regulated DC filament supply. Bias is adjusted externally from back panel jacks, and a separate meter specifically for the adjustment is included. The amplifier is an improved ST-35 circuit, with both channels on one printed circuit board. Tubes are GE 7247 and (2) matched JJ Electronics EL84 per channel. Transformers are Dynakit original spec parts. The amplifier is housed in a Par Metal chassis and rests on Cary Audio isolation feet. Alps Blue volume potentiometer.
Note: This is not an Erhard Audio product. I built this from an electronics kit from the company.
$500 plus shipping to CUS only
PM for photos or with questions
Photos hopefully attached
Really nice little amp with well made transformers, probably a good as the originals and certainly much younger. I wish I needed it. Can’t beat the price!
Good luck with your sale. Some lucky person will be very happy.
And reasonably priced too!
Considering the transformers ALONE amount to around $300, and the case around $75.
