FS: NAIM NAP-200 Clone Kit
Joined 2002
I’m offering a DIY Amplifier based on the NAIM NAP 200 ( the unequipped Boards I bought in Shanghai) almost completely assembled, just 4 pieces 47uf / 63V capacitors are missing. All semiconductors are original Motorola, Zetex and Sanken. Resistors from Yageo and Dale. Power transistors are NOS Sanken 2SC2922 including the matching micas. The MJE243 & MJE253 are Motorola. The ZTX753 & ZTX653 are Zetex the remaining are from Motorola. The 2N5089 (bias) and the 2SC2922 are not soldered because they are soldered on the underside of the board. The 4 main capacitors are 15000uF/50V from Jamicon. Both Toroid’s pri 2 x 115Vac, secondary AC27V-0-AC27V each 200VA brand-new. Toroid’s with electrostatic shield made by Sedlbauer/ Germany. Toroid dia:110mm height:53mm weight 2,2kg. Naim PCB size: 280mm*235mm. Output Power: 75W+75W at 8ohm load. I have 2 Sets available. Asking 150 Euro + Shipping from Germany + 4% Paypal per set. PM me if you are interested.
