I am selling a MiniDSP OpenDRC-DA8 Audio Digital Processor DSP 32bit S / PDIF RCA 8 channels with remote control, bought 6 months ago for which it is still under warranty and in perfect condition with the plastics
The price is € 385 + shipping
The openDRC-DA8 from MiniDSP is a multi-channel audio processor with floating point DSP at an affordable price. Powered by an Analog Devices Sharp ADSP21369 processor, the OpenDRC-DA8 engine enables complex processing such as digital room acoustic correction, active filtering for type IIR and FIR loudspeakers with high-level phasing speakers.
To obtain a fully functional device:
Measurements will be acquired with the microphone not supplied Umik USB 1.
Use the REW software for IIR correction measurements and curves: REW - Room EQ Wizard Room Acoustics Software
Follow this tutorial in English for filtering FIR.
The OpenDRC-DA8 also acts as a DAC (AKM AK4440) with its digital input SPDIF and its 8 analog RCA outputs. With its Asynchronous Sampling Rate Converter (ASRC), the digital signal is processed with a low jitter. Once configured, the configurations (4 in total) and the volume can be controlled via the rotary encoder or a remote control (not supplied), without the need for a computer.
Finally, the OpenDRC-DA8 as most MiniDSP products is intended to be an easy to use system, driven by a large community on the web working to improve and evolve the product constantly.
mini dsp DA8
Schematic diagram
TECHNICAL CHARACTERISTICS
Processors: Analog Devices Sharc ADSP21369
Processing type: 32bit floating point
Type of digital filter: FIR and IIR
Convolution engine for advanced / custom filters
Input: SPDIF 24bit 192khz
Outputs: 8x RCA Stereo with 2V Impedance 560ohm
FEATURES
DAC AK4440 with 8output channels
Front volume control
Remote controlled volume
Recall of 4 memorizable configurations
Active filtering 2x4 channels (8 channels)
Parametric Equalizer on 8 Channels
mini dsp DA8
Schematic diagram
FEATURES
