FS in Los Angeles: pair of JBL Control 328C/T 8" coaxial compression driver
Hello,
Was going to base the L/C/R of my system on these, but decided to go with slightly smaller Tannoys, which have been fine.
These are really well made, and in good condition. No shipping as they would be awkward to ship due to bulk (compression driver off the back, massive crossover board, etc.) One port fell off of each speaker, but that didn't concern me as I was going to use the speaker/crossover, not the mounting plate with the ports.
Looking for $183 for the pair, firm.
Best,
Tal
Factory JBL page:
Control 328CT | JBL Professional Loudspeakers
Specifications:
Frequency Response (-10dB) 45 Hz – 18 kHz
Power Rating See transformer taps
Transformer Taps 68W, 34W, 17W, (& 8.5W @ 70V)
Frequency Response (±3 dB) 60Hz – 16 kHz
Coverage Angle 120° conical, constant directivity
Impedance 8 ohms
Directivity Factor (Q) 7.0 (Avg 1k - 16kHz)
Directivity Index (DI) 8.5dB (Avg 1k - 16kHz)
Sensitivity 93 dB (1 kHz - 16 kHz)
Maximum SPL (1m) 118 dB (top 70V/100V tap)
Crossover Network 1.9 kHz, 3rd order (18 dB/oct) high-pass plus conjugate
Dimensions (H x W x D) 305 mm (12.0 in.) diameter round baffle x depth from back of baffle of 218 mm (8.6 in)
Input Connectors Screw locking barrier strip for bare wire
Drivers LF Driver: 200 mm (8 in)
HF Driver: compression driver, 25 mm (1 inch) coil
