All,
I am selling a pair Gainclone monoblock amps that I built a while back and haven't used much:
See http://photos.yahoo.com/vinnie822
FEATURES:
1) BrianGT's LM3875 boards with LM3875 mounted to rear plate for heatsinking
2) Avel Lindberg 22Vac 120VA torroid transformers
3) 50V, 2,200uF Panasonic FC caps, bypassed with 50V, 0.1uF poly caps
4) Eight On-Semi U860 rectifier diodes per unit
5) Rugged, integrated connector with switch, fuse, and IEC (30A 120Vac) all built-in
6) X2-rated mains AC noise suppresion cap in parallel with IEC input
7) Cardas RCA jacks
8) Nickel-plated speaker binding posts that will accommodate either a standard dual banana plug, up to 16 gauge bare wire, or spade connectors stacked up to 5mm high.
9) Black-anodized aluminum enclosure that measures only 4” wide x 6” deep x 2.5” tall
10) Solid "brick-like" construction (bolted torroid using Avel Lindberg's mounting hardware, BrianGT boards mounted using standoffs mounted to bottom of enclosure)
11) Clean wire routing with shortest possible cable lengths
12) Fully tested to be 100% functional with no noise/hum issues
***Very low useage (less than 20 hours total)
COST
I am selling these as a pair for $329 USD, which includes free shipping to the USA.
CONTACT
Feel free to contact me at vinnie822@yahoo.com if you are seriosly interested. I accept paypal payment.
Thank you,
Vinnie Rossi
FEATURES:
7) Cardas RCA jacks
COST
CONTACT
Thank you,
Vinnie Rossi
UPDATE:
I am reducing the price of the pair from $329 down to $229 USD, which includes free shipping to the USA. 😎
Thank you,
Vinnie Rossi
See http://photos.yahoo.com/vinnie822 [/B][/QUOTE]
Thank you,
Vinnie Rossi
Vinnie R. said:All,
FEATURES:
7) Cardas RCA jacks
COST
CONTACT
Thank you,
Vinnie Rossi
