FS - Focal TC90K Tweeters MATCHED PAIR Tweeters Mint Condition Unused.
Item: Focal TC90K Tweeters Matched Pair!
Condition: Mint, No solder on tags, have not been broken in, only quickly tested.
Reason for selling: Can only hold onto stuff like this for so long without doing something with them!
Price: $200 USD Or Nearest Offer.
Payment Method: Paypal Prefered for international.
Extra Info: The tweeters have not been used other than quick testing, the new owner will need to adhere the breakin time before gaining full performance from them.
These tweeters have a softer and warmer sound than the usual metal domes from focal but still have the imaging and sense of space. Can be easily crossed over at 2khz 12db or higher.
With a quick comparison to my Wilson tweeters these have a thicker warmer sound to them, although they are not broken in yet so they should only get better after 40-50 hours use.
Specs -
Response 1khz - 20khz
FS: 950hz.
Sensitivity: 92db
Nominal Power Handling UNFILTERED: 12W RMS
Nominal Power Handling FILTERED 2khz 12/db: 75W RMS
Cone: Kevlar
Nominal Impedence: 8 ohm
DC Resistance: 6ohm
VC Diameter: 20mm
Cone Diameter: 25mm
QTS: 0.90
QES: 1.21
QMS: 3.47
RE: 5.9 ohm
RES: 17 ohm
Please PM me if any questions
Julian.
