FS Bliesma T34B-4
Next up the Bliesma T34B-4 Beryllium 34mm large format tweeters and pains me to sell these. As they are simple top 4 tweeter available today no matter the price range. Nothing produce for mobile audio comes close.
Manufacturer BLIESMA
Tweeter Type Beryllium Dome Tweeter
Cone / Dome Diameter 34mm
Impedance 4 ohms
Power Handling (RMS) 80 W
Frequency Response 1300 – 40000 Hz
Sensitivity 97.5 dB
Features :
• 34mm beryllium dome with variable thickness for ultrasonic first breakup mode
• Extremely low moving mass for better transient response and higher efficiency
• Fully saturated neodymium motor with copper sleeve for low non linear and modulation distortion
• 3mm linear excursion and large vent channel for undistorted low frequency operation
• Narrow surround for less “soft dome” coloration
• Flush mounted surround and rear mounted magnet system for flat frequency response and wide off-axis response
• No ferrofluid for improved dynamics
• Underhung voice coil wound on titanium former
• Flexible and lightweight lead wires made in Denmark
• Thick aluminium powder coated flange
• Aluminium rear chamber with natural wool damping
• Gold plated wire terminals
• Extremely wide recommended frequency range 1.3kHz-40kHz
Asking $600 for these shipped in the U.S. will ship international add $50 U.S. to the price.
Still available? May be interested
Hey Mark, I don't want to get your hopes up, but I'm starting a build that these might be perfect for. Are they still available? I assume you're selling for $600 for the pair? I see these online new for what looks like $500 each at Solen. I see they were mounted... anything done to them that would make us worry?
Thanks,
Keith
